Display—touchscreen damage
Ceu
Beitrag von Ceu »
Hello
My ampera touchscreen turns blue and doesn't work. It has energy ,all the functions are working but the screen is dead. My mecanic says i have to buy a new one but is too expensive. Does anyone had the same problem?
Here in portugal there are few amperas and theres no experience on this kind of cars.
Thank you
Re: Display—touchscreen damage
Hi Ceu,
try to disconnect the 12V battery for 7 - 10 minutes and see if that fixes your screen.
If that doesn't help, did you see how your mechanic opened your center console? It is very easy to do and maybe you will find a simple fault, for example a broken / loose wire that causes your dead screen:
https://youtu.be/Hu2Zu8VZoDk?t=325
Otherwise you will have to buy a new screen from your dealer or ebay, you have to check the different prices:
http://www.ebay.de/itm/Chevrolet-Volt-L ... SwpLNX86Vg
http://www.ebay.co.uk/itm/2014-VAUXHALL ... 2496200302
http://www.ebay.de/itm/Display-20980651 ... SwpRRWphMx
Good luck!
